need shifter bushings
Posted: April 28th, 2008, 12:19 pm
by neli_nael
Re: need shifter bushings
Posted: May 8th, 2008, 12:04 am
by Ryan
What exactly is your problem?
If, perchance, you are referring to the link underneath the vehicle, and the squeak is driving you mad, you don't really need a new bushing.
I pulled mine all apart, took it to a wire brush bench grinder, took off all the rust, slathered it in lube/grease, and put it all back together. Shifting is easier, and doesn't squeak. :)
Posted: May 8th, 2008, 12:24 am
by neli_nael
Ryan wrote:What exactly is your problem?
i was putting in a short shifter and wanted to replace the bushings. i found it on corksport tho.
