need shifter bushings
neli_nael
Post by neli_nael »
94 mx3 rs
92 mx3 gs curved neck klze SOLD
Ryan
Re: need shifter bushings
Post by Ryan »
What exactly is your problem?
If, perchance, you are referring to the link underneath the vehicle, and the squeak is driving you mad, you don't really need a new bushing.
I pulled mine all apart, took it to a wire brush bench grinder, took off all the rust, slathered it in lube/grease, and put it all back together. Shifting is easier, and doesn't squeak. :)
neli_nael
Post by neli_nael »
Ryan wrote:What exactly is your problem?
i was putting in a short shifter and wanted to replace the bushings. i found it on corksport tho.
94 mx3 rs
