Hi i have a 92 GS-R with many problems, one of which being i need new drive axles.. should i just get axles for a k-8 or is there anything i could upgrade to? from what i gather a probe or mx-6 axle will not fit...
Thanks in advance
Need new front drive axles, K-8 Axles? Can i upgrade??
irocthaDOHC
- stereoking15
Re: Need new front drive axles, K-8 Axles? Can i upgrade??
the new axles from napa are pretty good they are heat treated to accept more punishment and have a lifetime warranty bout 80-110 u.s.d . but if you need extensively bullit proof axles corksport has em for bout 600 u.s.d
irocthaDOHC
- mx3autozam
I ahve napa remans and there ure garbage, and I also believe they are giving me protege ones that are too short and when I turn the joint pops out of the inner cup. Thats not right. I dono but maybe the Napa new ones are good. But i do not want to wasre more money on axles that might be junk again.
Anyone tried axles from part source or something?
93 Mazda MX3 KLZE Turbo
- mitmaks
http://www.autopartswarehouse.com/searc ... 66236+9274" onclick="window.open(this.href);return false;
http://www.a1cvtech.com" onclick="window.open(this.href);return false; GREAT Customer support and awsome products.
- stereoking15
if you want some beastly axles then here you go
http://www.horsepowerfreaks.com/perform ... rain/Axles
