Pic request: rear seat removed, what to do with the 'space'.
jamesmx3
Post by jamesmx3 »
I been searching for a picture of an mx3 with no rear seats, but with the 'space' covered with carpet. I know I've seen one on here some where. There was also one with a sort of built up section that made it look like a Proper two seater. If any one could link these or post the pics that would be great.
1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com" onclick="window.open(this.href);return false;
Kirk95gs
Re: Pic request: rear seat removed, what to do with the 'space'.
Post by Kirk95gs »
When I had my 93 I removed the rear seats. Fabed a custom sub box out of 1x1 pine. Once I had my design layed out I covered the structure with some old pool talbe felt I had form work and put fiberglass resin over it. did this 2 times I think. Sanded and Painted flat black, cut out for the speakers and mounted the amp. I had two 10 subs on a 30 degree angle pointed at the front seats and the amp placed in the center. I think it took me a week to do.. just doing a bit after work each day..
I dont think I have any pictures. But I will check my old pc when I get a chance..
jamesmx3
Post by jamesmx3 »
That's a good idea, as the firberglass will keep the weight down! :D
96mx-3
Post by 96mx-3 »
i took out my seats...and i measured roughly how much carpet i needed ..and i bought liek a felt ? i think... and then took off the carpet from the back of the seat and used it as a template..but the back doesnt cover the floor compeletely...then cutt it out and layed it innnn
wickedmx3
Post by wickedmx3 »
Yeah, my audio guy has been dying to rip out that seat and spread the audio system from the trunk into that back area, his idea consisted of a fiberglass enclousure for the set up...I have been reluctant to go that route, though honestly, I NEVER use the back seat. Except as a trunk since I don't really have one anymore.
somorecords
Post by somorecords »
yeah i pulled the back seat and built a enclosure for 2 twelve inch subs, and my stereo hookup has about convinced me to convert whats left in the back to a 15 inch enclosure for a rockford p2 but i havent decided yet
Return to “Appearance”
