Mazdaspeed LSD
Unreal-Icarus
Mazdaspeed LSD
Post by Unreal-Icarus »
Hi guys,
i'm planing a gtr engine-swap within the next months and i was wondering what LSD i should use with the 1,9l protege/323 LX tranny. I've read alot about phantom Grip Mazdaspeed and quaife lsds here, but quaife is much to expensive for me, phantomgrip is said to be no that good and the mazdaspeed lsd i cannot find anywhere. Could you give me an advice where i can get one ? If the MS lsd works like the phantom grip, why should it be better ? i expect the price is higher too...
Would be the 1,9l protege/323 LX tranny the right one to use ? i won't go higher than 250 hp.
thx
greetings Icarus
Re: Mazdaspeed LSD
Post by wytbishop »
wytbishop wrote:I priced eerything necessary for a MazdaSpeed LSD retrofit with MX-6 5th gear last week at just over $1000.
QTY Part# Description
(1) GSY1-27-190 MazdaSpeed Protégé LSD...........$646.31
(1) F520-17-628 Primary Shaft Locknut................$17.48
(1) G501-17-629A Secondary Shaft Locknut............$14.25
(1) G501-17-341A Speedo Drive Gear....................$13.41
(2) G5R0-27-350B Carrier Bearings......................$46.51ea
(1) G560-17-611C MX-6/626 Primary Shaft 5th Gear..$99.90
(1) G514-17-308 MX-6/626 Secondary Shaft 5th Gear...$96.33
Total...............................................................................$980.70 +tx
There is a very thorough write up on imazda.com in the how to section.
http://www.imazda.com/forums/showthread.php?t=2701" onclick="window.open(this.href);return false;
I'm not sure if it's as bulletproof as the Quaiffe, but seems solid and for $1000 you'd have a pretty scookum tranny.
This is a post I made a couple of weeks ago. My local Mazda dealer said I could have all of these parts ina week, so they're probably in the warehouse in Toronto.
If you had searched the Transmission forum with the word LSD, this would have been one of the first results...I'm just saying.
Unreal-Icarus
Re: Mazdaspeed LSD
i know that post but didnt recognize the mazdaspeed lsd -.-. damn.
and this lsd fits the protege tranny ? just want to be sure, im from europe and have to import that ...
Custommx3
Site Administrator
Re: Mazdaspeed LSD
Post by Custommx3 »
That forum link requires a login.. can you copy that here? let us make a FAQ?
Re: Mazdaspeed LSD
Post by wytbishop »
I believe the author is a member of this board as well. He is Mazdaracer on iMazda and I'm pretty sure the guy with that name here is the same guy. I have sent him a pm regarding posting it for us.
Re: Mazdaspeed LSD
Post by wytbishop »
Unreal-Icarus wrote:i know that post but didnt recognize the mazdaspeed lsd -.-. damn.
The original post on iMazda was done using a Protege tranny I think. The LSD might cost you a fair bit to get, but everything else is small and would fit in a small box. If you have a friend here, they could get the parts and ship them to you easily.
Unreal-Icarus
Re: Mazdaspeed LSD
thx 4 your answers !
Return to “Transmissions”
