rear brake issue
GregoryChristian
rear brake issue
Post by GregoryChristian »
after inspection my rear brake drum has a leak .. the rubber boot on the brake cylinder has a small tear and is leaking fluid ...can I purchase a new set of rubber boots or do I have to buy the whole cylinder ...also just noticed my brake bleeding screw is broken off ...what do I need to buy to fix that problem too ?
2fazed
Re: rear brake issue
Post by 2fazed »
Here's the time to swap them to disc brakes. Then you don't have to worry about the rear brake cylinders leaking.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
mitmaks
Post by mitmaks »
I would change whole wheel cylinder. You dont want to mess with them, I remember one failed on our old blazer and brakes failed. Glad there were no cars around or it could've been major accident.
