engine swap
dubspeed
engine swap
Post by dubspeed »
after swapping the 1.8l out, and inserting a 2.5L kl-ze, it seems the ground wire from thew battery gets warm, and when i try to start the car, it only ticks...ANY HELP OR OPINIONS IS MUCH APPRECIATED!! THANKS IN ADVANCE!
Custommx3
Site Administrator
Post by Custommx3 »
You sure you dont have it backwards?
dubspeed
Post by dubspeed »
i swear its not, sumthing is backwards though....seems the starter sparked a little when i tried turning it over, and when i applied the brakes, the door beeping stopped....
Custommx3
Site Administrator
Post by Custommx3 »
Triple check your battery and starter wires.
Take off your starter, have it tested. Battery too.
Can you turn over the motor by hand?
mx3autozam
Post by mx3autozam »
bad grounds!!
Tunes67
Post by Tunes67 »
I had quite a few issues getting my starter to spin properly and consistently after I did my ATX to MTX swap. Part of it was grounds.. part of it was the power to the starter. I replaced the main starter power cable and ran a ground cable directly to one of the starter mount bolts. Starter spins like a windmill in a hurricane now :D
Tunes67
