Speedometer prob....
Posted: October 19th, 2007, 12:36 am
by se7en
okay, I just noticed, that my speedo doesn't work anymore.
did I forget to plug something in? or did I miss something?
sorry to be such a forum hog, but I think that I am running into problems that a lot of people will run into in the future.
thanks
7
Posted: October 19th, 2007, 4:48 am
by fatray
I thought all the dials came off the same fuse, and the speedo comes off the front wheel speed sensors, but if they either of them was screwy then your ABS light would be on. (this is all coming off the top of my head)
Do you have ABS? CEL?
I'd guess you didn't plug everything in, or trapped a wire or something. when did it work last?
Or maybe you just stopped moving.
Posted: October 19th, 2007, 8:42 pm
by Ricky_Bobby
Might be your VSS..
But i don't see the problem, the mileage doesn't add on anymore :P
Posted: October 20th, 2007, 12:06 am
by Raven95150
You probably didn't plug in the VSS. (speedo sensor) It is on top of the tranny, way at the back pretty much right above where the shift linkages hook up.
Posted: October 22nd, 2007, 12:45 am
by se7en
okay, thanks! I think that I will hook up the speedo again and remember where the rpms are for different speeds, and then unhook it again!
heh, I am so bad!
