True KLZE?
curt
True KLZE?
Post by curt »
Hey, am looking at a KLZE. Was just wondering if it is a true KLZE - have heard of people getting ones that look similar but are not. So yeah, real or not real? Is there a way to check without having to check the heads?
Link: http://www.jdmtigerjapanese.com/product ... cts_id=149
Thanks!
-Curt
solo_ryder
Post by solo_ryder »
Looks like a KLZE to me, however, a true KLZE is a straightneck IMHO, kl31 cams are the way to go. Get a straight neck and you cant go wrong, then just buy a curved neck IM for it.
Smith18
Post by Smith18 »
yeah in my own opinion a curved neck ZE is almost like a KLDE.... might as well take your money and buy a DE and build it up.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
94mx3precidia
Post by 94mx3precidia »
ya they pretty much covered it. you have like a 50/50 chance of it being a true klze seeing as how ull be paying for shipping and if it turns out to be a de then youl have to ship it back and gunna cost ya alot of $$$ so u might as well buy a straight nect then buy like a millenia IM and u know for sure it the real s---.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
curt
Post by curt »
So if I get the straight neck KLZE, and throw a curved neck intake manifold on, I won't have to swap out injectors or anything will I? It would just be bolt on right?
-Curt
solo_ryder
Correct
mx3autozam
Post by mx3autozam »
All 2.5's or as i should say KL use the same injectors.
Definitly get a straight neck and swap curved neck manifold on it, make sure you get the correct throtle body for the curve neck because its 60mm compared to the k8 which is 55mm and it will affect the performance of the motor.
93 Mazda MX3 KLZE Turbo
mx3autozam wrote:All 2.5's or as i should say KL use the same injectors.
Doesn't the curved neck COME with the correct TB??
Juans_93_MX3
Post by Juans_93_MX3 »
A straight neck can actually fit in a MX3 though with some modifications
When you guys say millenia IM, do you mean as a millenia IM from a KLZE engine (J-Spec Millenia)?
Whats the difference between a curved neck ZE and a DE I/M?
2008 Mazda 3
1993 MX3 GS
mx3autozam
Juans_93_MX3 wrote:A straight neck can actually fit in a MX3 though with some modifications
There is no difference!
Exactly. The curved-neck Millenia DE has square runners like a ZE, it's one of the reasons why the Millenia is rated for 170hp rather than 165hp
hgallegos915
Post by hgallegos915 »
Dont forget this is from tiger jap... just watch out and go look at the engine yourselfbefore buying.. or ask for pics.
-hec
havoc13
Post by havoc13 »
where in ontario are u? i got mine done in mississauga at diamond japan and they have a couple other zes sitting around i got a curved neck installed 1900 with a new timing belt and water pump and it was done in 2 days
Always under construction
mx3autozam
Nothing wrong wth Tiger Jap at all..I had probably one of teh cleanest ZE's on this entire website and it came from Tiger. I went and looked at the motor they were selling me and it was infact a true straight neck klze.
mx3autozam
I've known people to buy a Curve neck manifold used and it never had a throtle body, sure you can use a k8 but its smaller.
