how much do i need to retard my timing to run 150-175 shot. it will be running through a direct port setup and a progressive control. the motor is fully built (top end with new valvesprings and retainers and valves as well as reground cams. the bottom end with rods and pistons.
i know that the general rule used with hondas is approx 2 degrees for each 100 shot, i think its a bit much when talking about a car that's set at 10 detrees btdc. thanks
how much timing retart
comish71
1993 MX-3, KLZE, HOTSHOT HEADERS, CUSTOM EXHAUST WITH WALKER QUIETFLOW, K&N INTAKE, DIGITAL 6, QUAIFE LSD, FIDANZA FLYWHEEL, CLUTCHMASTER STAGE 3, GROUND CONTROL COILOVERS
14.32 @ 95.4mph
14.32 @ 95.4mph
- Franko
When you are setting the engine at 10 btdc that is only setting it up with the ecu because thats what it uses as a basis for all the ignition control.
Under high reving with little load its probally putting 30 degrees or so and when under a full throttle condition its probally around 25ish..
The question is how are you controlling your timing? If you move your distributor back a few degrees that is going to affect your whole timing map and probally slow the car down.
Otherwise Id say go with what the honda boys use.. 2 degrees aint much. Better to be safe than sorry.
comish71
i am controlling my timing with my msd box. when i turn on the switch for the nitrous it sends a signal to the msd which retards the timing by the amount set
14.32 @ 95.4mph
14.32 @ 95.4mph
blackops032
- BANNED Member
