My engine seems to run a bit hot. I dunno what the normal temp is, but on other cars the guage usually hovers around the middle. On my mx it's slightly above that. Fan and fluid is fine. Could it just be an old thermostat?
Also, is there any major differences between the SOHC and DOHC I should look out for when using the workshop manual for work on the SOHC?
Thanks.
