help findings msd products
93mazdamx3_93
i can't find a Msd distributor, box and wires for my kl-ze. any help? thanks
Mnemonic
MSD 6A, PN 6200 you can get it online just about any online performance parts company and probably ebay
MAGNECOR 8.5mm Performance Plug Wires just as good as msd if not better, you can get these directly from http://www.corksport.com just make sure you get the ones for the mx-6/probe/millinia/626 basically the ones for the klde there longer and will fit better. Call Dereck at Corksport when you do tell him you need an additional wire for the coil wire as you are using the klze disty.
You can also get the exact spark plug for the klze from corksport but the klde ones are the same
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
93mazdamx3_93
hgallegos915
Beefing up the ign system doesnt really give you gains, just smoother idle.
I had the understanding that if you did the hei mod, its the same as having msd, sorta.
-hec
Mnemonic
actually it will give you a boost in power slightly, more than likely a little more torque (dont expect to much) but yes it will deffinetly be a big help in the ignition setup. Will help to produce more power as you go further along with your setup
