hey watsup guys im new to this forum... I have a 94 Ford Escort GT w/ a swapped JDM Klze.... the stock speedo cluster is ran by cable on the escort butt the mx3 tranny has a electronic plug.. neone kno of a calbe speed senor that will go into the mx3 tranny with no problemS??
Thanks for the help... please
Escort KLZE Speedo problem...?
EscortKLZE
94 Ford Escort GT - JDM KLZE.....
hgallegos915
please sbhow pics even better videos! tehres a guy tghat has an escort wagon with a klde which is basically the same swap. He can help you out. Search for him in the forums. I havent seen him post lately.
-hec
KLDE Wagon
I'm here to save the day!!! Ok here is what you need... a 1st gen probe v6 or a zx2 VSS, same thing. When you get it, pop the little plastic thingy out of it (it is green in color) and plug in ur speedo cable. DONE! hehe
as for the VSS actually being hooked up (for cruise or a speed cut<<<pffft) just cut the plug off of the car you get the VSS from and wire it up to the mx3 harness
Jeremy
Jeremy
