I have a 94 Mx-3 1.6L DOHC with an auto tranny. The engine is tired so I purchased another engine from the same year car except it was a manual tranny. I cannot get the transaxle flush with the block. I used the flywheel and torque converter from the old engine. These items mounted just fine. The bolt pattern on the engine and transaxle is correct. I have tried several different ways and still no go. Im hoping that this conversion is even possible or maybe Im overlooking something simple. MX-3 gurus please help!
To summarize: trying to mount an auto tranny on a manual tranny block...
Thanks
94' 1.6L DOHC manual to auto trans
- Tunes67
There is no difference in blocks.. as you have already done.. you will need to use your flex plate from the old engine on the new one.. the only hint I can give you is to NOT bolt the torque converter to the engine yet.. seat the torque converter fully onto the input shaft of the tranny.. then bolt the engine & tranny together.. then come from under the engine at the tranny inspection window and bolt the torque converter to the flex plate there. Rotating the engine so that you can line up the bolts one at a time and tighten them down till all are done.. Its a pain to do it this way.. but its often the only way to get the torque converter to seat fully onto the transmission input shaft. Hope this helps.
Tunes67
Tunes67
