I have an oil leak that loses about 1/3 of a quart within a week and then stops leaking. The PCV valve seems to rattle ok, could it still be the culprit?
I'm am a newbie with car mechanics, but am kind of assuming that the leak must be high up somewhere where not all that much oil reaches, like the PCV?
Temporary Oil Leak when full
comish71
do you see any oil at all externally. if you do, you can degrease and then observe closely for a source. is the car smoking at all like piston rings.
externally, especially on the passenger side beneath the timing belt cover you need to consider the crank and cam seals. if coming from the valve cover, think about the valve cover seals. if seen in the spark plug reservoirs then think about the tower seals for the plugs.
1993 MX-3, KLZE, HOTSHOT HEADERS, CUSTOM EXHAUST WITH WALKER QUIETFLOW, K&N INTAKE, DIGITAL 6, QUAIFE LSD, FIDANZA FLYWHEEL, CLUTCHMASTER STAGE 3, GROUND CONTROL COILOVERS
14.32 @ 95.4mph
14.32 @ 95.4mph
