I don't have alot of pics of the final product but i will be taking pics soon, i do however have some pics of me in the process of putting it together.
I will list whats included:
HotPipes:
-MMI Turbo Hotpipes Powdercoated with 2200 deg. Insulating powdercoat
-EGR Welded Shut
-Turbo Up-pipe modified to fit MX-3 Engine bay
-Downpipe is cut to bolt up to Turbo housing and needs a 2-3/4" extention peice to mate up to full exhaust.
-Downpipe has a 02 bung welded in for wideband 02 sensor
-Up-pipe is wrapped in black header wrap, just by portion that goes by the bottom coolant line, approx 8"-12" Uses Stainless steel clamps for clean look
Cold Pipes:
-Completely Custom Intercooler Setup
-2.5" Aluminum Piping Powdercoated black
-RED 3-ply couplers
-T-bolt clamps for added strength
-29x8x3.5" Same Sided Intercooler 2.5" inlet and outlet
-Blow off vlave flange for a 2-bolt (Greddy Type S)
-Greddy Type S knock off blow off valve (Anodized RED)
-Aluminum Anlgle for mounting Intercooler in stock bumper support location.
Turbo:
-T3/T04E 57 Trim
-Inlet 3" --- Outlet 2"
-.50 A/R Compressor (Exducer 3", Inducer 2")
-.63 A/R Turbine (Exducer 2.2", Inducer 2.58")
-.58 5 Bolt Standard Hotside
-Hotside Turbo Housing Powder Coated with 2200 deg. Black like Upipe.
Turbo Oil Fittings:
-3/8" NPT To 4an Fitting for off the block
-4an 36" Stainless Steel line For oil feed
-4an 90 Swivel joint for turbo feed
-Function 7 Aluminum 4an Restricted Oil feed for Turbo
-Function 7 Aluminum Adaptor for Oil Drain
-(2) 5/8" Barbed fitting for oil drain
-5/8" Heavy Duty Hose for oil drain ~36"-42"
-Tapped Oil pan with Female 3/8" thread
-(2) clamps for 5/8" Hose
Wastegate:
-Standard 2-Bolt 38mm Wastegate
-Tial Knock-off
-Wastegated for 8-psi
Fuel Accessories:
-Millenia S Injectors (Redtops) in KL Fuel rails
-Cartech BEGI FMU with 5/16" barbed fittings (Fully adjustable On-set and rising rate)
-MBX Fuel pressure regulator adaptor with 5/16" barbed fitting
-Adjustable Fuel Pressure Regulator
All bolts are heat-treated Grade 8 with washers and Nylock nuts, which is the bet you can get.
Of course i would prefer pick-up but since i need to sell this ASAP, i will be willing to ship at the buyers expense.
Any questions please feel free to contact me, i will be posting new pics of the final install soon.
Asking price is 2,000 + Shipping which is a steal for such a show quality kit.
