broken stabilizer
broken stabilizer
so my stabilizer was broken when i bought my car, and i didnt notice because it hadnt dislodged yet. but i hit a huge bump the other day and it fell down and wedged into my tire..so i took it off today. gonna try to weld it back together tomorrow to give me a temporary fix until i can get a new one...but i was wondering if there were any other cars that had the same size one to fit mine, since mx-3s are pretty rare where i live. i might be able to go steal one off an mx-3 thats flipped over lying in a field around here, but if not...anyone know if any other car has the same stabilizer?
~'92 1.6L tropical emerald metallic mx-3~
k & n cold air intake & a 4" carbon fiber tip
- PATDIESEL
The only other car I could think of that "might" work is a 323, but since I wouldn't want to buy two stabalizers I would just buy the correct MX one first.
Should be one on here from someone parting a MX-3.
- PATDIESEL
You could also get a GS one for better handeling, but you MUST get the front AND rear and install them at the same time. A GS front with your RS rear would make things worse.
GL
- lowridah313
Thanks Pat send them my way!
Representin' the THRE3:TH1RT3EN
'02 Nissan Xterra SE, atx, 4x4, 32's
'92 Geo Tracker atx, 4x4
Feedback http://mx-3.com/phpBB3/viewtopic.php?f= ... 54&start=0" onclick="window.open(this.href);return false;
- Yoda
The ones from the 323/Protege will bolt-in without any problems except you will need custom end links because the eye is clocked differently. The 20mm bars are hollow and are about the equivent of a solid 13mm bar the 22mm OEM bars are soild like the '96 MX-3 GS's.PATDIESEL wrote:The only other car I could think of that "might" work is a 323, but since I wouldn't want to buy two stabalizers I would just buy the correct MX one first.
