plastic covering on seat tilt levers keep falling off
so the little black plastic thingies on my levers to tilt my seats keep falling off....should i just appoxy (sp?) them on or is there a better way to get them to stay?
~'92 1.6L tropical emerald metallic mx-3~
k & n cold air intake & a 4" carbon fiber tip
- PATDIESEL
If you look carefully you'll see where they clip onto the lever. If it is broken you are stuck with glueing it. If it is not broken just make sure you get both clips snapped on and it should stay.
- Hoodzy
umm yah if they are broken, epoxy or a super glue called FLASH.. i'm not sure if flash works on all plastics but it will basically melt them together which will giveu the strongest bond should be able to get at any hobby shop for about 9 bucks
1995 Creek Mica Blue GS
