Specs:
Newer bp from japan..I'm not sure if there's a difference between the old and new as far as sensors or cam stuff...
LF: 95+ BP ECU and 95+ BP Distributor
- mr1in6billion
The new BP has coil & module inside the disty - just like B6 DOHC
http://cgi.ebay.com/ebaymotors/97-98-Ma ... enameZWD1V
The ECU is tricky - although the engine model is lumped as 95-98 the ecu and harness underwent changes almost every year (for obd2 compliance i think). For example - i have a 95 ecu and harness and a 96,97 or 98 ecu wont plug n play in my harness. You have to get the harness and ecu matched...
94 Mx-3 Precidia
