Moisture in tail lights
I have a set of altezzas on my MX-3 and they are really foggy.. and I just got a set given to me because his were really foggy as well... even worse than mine. So right now I have them in my apt drying until I can figure out what to do with them. one of the tail lights brackets are busted so Im kinda stumped on how I should actually go about siliconing them... and I really dont know which silicon to use. The stuff i used on my tails that are on the car now just ended up coming off... I have pics but I dont know how to post them on here... can someone help me out
- PATDIESEL
Swap the half broken ones onto the car. Take your unbroken set and let them dry out 100%. Then clean the area to be siliconed with some paint thinner or acetone to clean the surface. CAREFUL, both paint thinner and acetone will eat or dull the clear plastic covers. Then sand with some 80 grit sand paper to rough the surface of the area to be siliconed. Then apply some general silicone from Home Depot. I would use some clear silicone III in a tube. Let it dry for 24 hours and reinstall in the car. Sell the half broken ones when you are sure your's aren't taking on any more water.
