94 1.8 Camshaft position sensor...
ExperimentX
Could someone just clarify to me please where this sensor is located? Is it inside the distributor or somewhere on the outside? My car has started running all snafu and the code I got from the obd 1 is code 03 which is the camshaft position sensor... thanks guys!
- solo_ryder
Does your car start at all? There are really 2 sensors for that, but one is the crank sensor by the crank pulley on the bottom passenger of the motor. The other is located in the distributor and that would throw the number 3 code as you are getting. However, if that is the code your getting then your car must be running really bad. Is that true? If not try resetting your ECU to see if that helps. If you car is running ghetto, I suggest getting a new Disty.
- PATDIESEL
Not so fast. Actually the ECU calls both of those sensors a cam position sensor and they are both code #3. So what you should do is bring the car to a mechanic and have them test both sensors and tell you which is the bad one. The "cam position sensor" that is really the crank positon sensor is not expensive, the one in hte disty is going to be expensive since you need a new disty if it is the bad one. So that for the 3-400 cost of the disty I'd have someone check and tell me which is wrong b/c the one on the crank is only about 30 bucks if I remember corretly.
ExperimentX
ExperimentX
ExperimentX
- solo_ryder
ExperimentX
So is the actual camshaft sensor located internally in the disty or is it that little knob that sticks out on a wire?solo_ryder wrote:Thanks for the info Pat, that does make sense.
Yes, you could take the disty back because even if it was new, they have a tendency to go. That could the first palce to start. If it is the crank angle, that is a easy exhchange that you can get from any wreckers.
- solo_ryder
ExperimentX
