imagine this swap in the mx
- PWRD_BY_HKS
ok so this came to me when i saw the mx-3 for sale on ebay with the rotory motor...ok if you can swap in a ls-1 in to a rx-7.... then could you do it to the mx-3...i mean is there enough space in the bay...just a thought
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
jbaysinger
Re: imagine this swap in the mx
No way. Engine is way too wide (long), and there isn't a FWD transaxle that will mate to the LS1 that I know of.PWRD_BY_HKS wrote:ok so this came to me when i saw the mx-3 for sale on ebay with the rotory motor...ok if you can swap in a ls-1 in to a rx-7.... then could you do it to the mx-3...i mean is there enough space in the bay...just a thought
- Tunes67
You'd have to do something funky about the radiator most likely.. and you would have to have no life and a ton of cash to do it.. but it could probably be done..
Tunes67
Tunes67
Juans_93_MX3
Thats why you make it RWDjbaysinger wrote:No way. Engine is way too wide (long), and there isn't a FWD transaxle that will mate to the LS1 that I know of.PWRD_BY_HKS wrote:ok so this came to me when i saw the mx-3 for sale on ebay with the rotory motor...ok if you can swap in a ls-1 in to a rx-7.... then could you do it to the mx-3...i mean is there enough space in the bay...just a thought
Yes it is possible to put a LS1 in it. Hell I once seen a V8 Beatle and Ford Focus!
Lets not forget about V8 Miatas and even a V8 Honda CRX
Ofcourse, they were all RWD
A V8 MX3 would be awesome!
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- PWRD_BY_HKS
i mean i think it clears....
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- PWRD_BY_HKS
that would rule ...seriously...can you imagine squeezing a single turbo ls1 in there.......SICK!!!!
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
jbaysinger
Erf. well, okay, I wasn't thinking of a RWD conversion. That'd be sick, but I don't even want to think about the number of zeros behind that kind of operation. Would probably have to cut and fab the firewall and belly pan to make room for the tranny, and you'd have to find a new route for the exhaust, 'cause the driveshaft would be using the "tunnel." Unmuffled Cobra style side pipes? hehJuans_93_MX3 wrote:Thats why you make it RWD
Ridiculous. It's making my head hurt. I quit.
- PWRD_BY_HKS
yeah man but it would be like a track only vehicle...i think it should clear under 10k
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
I tihnk that yo dont see is the RWD gearbox, although you dont see it, there's room in the tunnel for it. Mx-3's dont have (a large enough) one because it's not RWD.
Your Mx-3 would lool similar to this in the end
