soon
the middlepart of the rear bumper
the roof
the 1,6 spoiler
and much more!
wil be come carbon fiber
update my cardomain page!!!!
http://www.cardomain.com/ride/512956
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.An Artist can make do with the tools at his dissposal...reaper of souls wrote:actually most fiberglass supply stores can order carbon fiber sheets in and it not really any more expensitve then fiberglass mat you just need to get a poly-resin for it you can set it the same way you do fiber glass or you can do vacucm baging for it all you need is a large clear bag and a shop vac to get the same effect as the 400 equipment
just take a bit more time and effort to do
Actually I think he was simply suggesting people PRACTICE with the cheap fiberglass, and poly resin.. then after getting a hand on working with the generall type of materials (fibre matting & resin I vac bagging) before moving on to working with the real stuffreaper of souls wrote:yes you could use crapy canadain tire fiberglass mat but you have to remember if your going to use crappy product your goning to end up with a crapy product no matter what what you cover it in !
it's better to do things right the first time and not have to do it over again at least don't use the canadain tire poly resin it's crap and has been sitting longer than it has been on the shelf it's just no good to work with pay the little extra for the good resin
