Painting advice
Painting advice
hey i just picked up a 93 egt for my new daily driver among other things it needs a paintjob pretty bad and i would love to do flat black (primer black) should be easy to do and repair if it gets scratches and dings... I know some magazine did this to a wrx once and they just used spray cans... would this work ok or does anyone know another type of paint i should use?
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
wow only 4 or 5 cans? was that only one coat? how has it held up and do you have any pics?
ProjectMx
Cardomain
Cardomain
yaa i only did one coat it held up awsome until i went to use the snow brush to push snow off it the other day now it has some scratches for pics of both my cars go to http://www.streetlethalconcepts.com/andrewr
- mitmaks
4 5 cans wont do it. I would just save money and wait till you can get it repainted.
there is no way i'm going to save up and paint this car professionally.. this is my daily driver/beater... the only car getting a good paintjob is my AWD mx-3, all i want is something that will look better than my smashed up mx-3 i'm driving around
ProjectMx
Cardomain
Cardomain
- rsroadkilla
im currently painting my mini in matt black using rattle cans.
I used 2 cans on the engine bay, so i reckon it will take quite a few more!
Give it a quick sand with a real fine paper just to key the surface, slap on a bit of etched primer and lay on the matt black!
Its looks pretty good, but make sure you key the surface first otherwise it will just flake off!
key the surface? sorry don't follow?
i was going to use some kind of air powered tool (die grinder maybe?) to sand the car down and use sand paper for small areas the air tool couldn't read
ProjectMx
Cardomain
Cardomain
- rsroadkilla
- mitmaks
Re: Painting advice
Magazine tried to do it cause they wanted it to look like mad max car. Mad max car doesn't look anything close to it. So they dont know wtf they were doing. Personally I'd leave car alone the way it is.projectmx wrote:hey i just picked up a 93 egt for my new daily driver among other things it needs a paintjob pretty bad and i would love to do flat black (primer black) should be easy to do and repair if it gets scratches and dings... I know some magazine did this to a wrx once and they just used spray cans... would this work ok or does anyone know another type of paint i should use?
uhm if i leave this car how it is then the rust will finish eating through the car and i'll have huge dents... why would i leave it like that? when for maybe 100 tops i could fix the dents and put a halfway decent paint job on it?
ProjectMx
Cardomain
Cardomain
- mitmaks
spraying primer on rust wont help. Primer does NOT stop rust.
so if cleaning, sanding, re-cleaning, spraying a self etching primer then primering the car won't get rid of the rust that was there what will?
ProjectMx
Cardomain
Cardomain
