and for sum reason when i push my subs
my amps dont work for a day then jus start working again, this only happens sometimes
but usually it jus cuts out the bass and u simply have to turn off the headunit
and turn it back on to fix the problem..
i dunno what it could be
faulty connection?
my headunit is alpine cda-9857 if that helps
could it be simply the combination? cuz i do have another amp
hooked up to my third 12" type r... i dunno
thnxz in advance
