ze turbo
- XxantwawnxX
Sure you can, is it worth it for you...i dont know.
even a 4 psi turbo ze is worth it, u need moooney and time tho. Determination too.
-hec
- Custom_V6_Limited_SE
I love the idea. I was thinking of it myself after I graduate (Computer Science + Computer Engineering = Massive Money). Something like twin dual ball bearing turbos from Garrett. Would make for some really nice low end spooling. Would probably have to custom fab the headers for it (along with other things).
'93 MX-3 GS SE:My Mods
