high pitch noise from Rockford amp?
Car Stereo/Alarm Discussions
chertel
Post by chertel »
I have a rockford amp and when I start the car there is a annoying high pitch squeal from the amp then it goes away after a few minutes? I checked all the grounds and everything is good. I thought maybe it was because of the cold weather but last winter it worked great.
any help, ideas :idea:
thanx
Vanished
Post by Vanished »
does it have a fan?
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
jschrauwen
Post by jschrauwen »
Have you changed your ground between last winter and now? Sounds like maybe a ground loop problem. DO NOT ground your amp back to the battery. Use the same gauge wire that's powering the amp to run the shortest ground lead possible to a solid frame connection point.
chertel
Post by chertel »
It is the P600Ibd rockford punch mono. It's all chrome and lights up a red rockford logo if you have seen that style before? I dont think it has a fan? I will try a shorter ground wire if I can relocate the amp because it is mounted on top of the sub box now so a longer ground wire is needed. Thanx for the help. It is freezing here in edmonton now so I have to wait for it to warm up before I play with it.
Another question, other than the anoying sound will it hurt anything else if I still use it before fixing it? Because the sound goes away after the car warms up.
thanx
chew*
Post by chew* »
Try running your rca wires down the opposite side of the the car that the power wire is on. If that doesn't work i suggest using a higher quality rca cable.
superman_t11
Post by superman_t11 »
i ahd the same problem, my rca wires were loose. try checking those it was a simple fix
chertel
Post by chertel »
I'll check the connection to the cd player, the connection to the amp is good. They are rockford rca wires but dont look like the greatest quality. I had a set of phoenix gold rca wires on my last car that were of much better quality. I think I'll just upgrade the rca's. Thanx. I think thats the problem, yesterday as I pumped the brakes the sound went +- with the pumping of the break and now that the weather has warmed up a little the sound is not as bad and goes away after a short while. Probably poorly insulated rca's.
thanx
chris
Cy
Post by Cy »
Easy fixes...
-Move the wires to the opposite side of the car
-RCA ground loop isolator
If nothing else
-Higher quality shielded RCA Leads
Return to “Car Stereo/Alarm”
