Where or is there a Fuse for Fuel pump
Posted: October 30th, 2006, 3:06 pm
by ven
car will turn over but wont start just happened. with key in the on position cant here the fuel pump under the back seat. Is it pouched or is there a fuse that might have gone bad and where would I find it...
or would it be something else
Car 96 mx-3 v6 gs 5 speed
stock motor
Re: Where or is there a Fuse for Fuel pump
Posted: October 30th, 2006, 3:16 pm
by jschrauwen
ven wrote:car will turn over but wont start just happened. with key in the on position cant here the fuel pump under the back seat. Is it pouched or is there a fuse that might have gone bad and where would I find it...
stock motor
Relay at passenger side of center consol kick panel - right beside ECU. Also fuel injector relay(s) under the hood.
Have you not sought the information from the online shop manual? Start with page F2-105 and then proceed onward.
Posted: October 30th, 2006, 3:20 pm
by ven
drivers side? is there a test to see if my pump is good or bad even if the hum isnt there
Posted: October 30th, 2006, 3:22 pm
by Custommx3
Also a relay attached to the side of the ECU.
Posted: October 30th, 2006, 3:33 pm
by jschrauwen
ven wrote:drivers side? is there a test to see if my pump is good or bad even if the hum isnt there
Yes, like mentioned previously, it's covered step by step in the online shop manual.
Posted: October 30th, 2006, 3:51 pm
by ven
ok said theres a relay on the passanger side wall is that under my stereo or the door side also what is a ECM ?
Posted: October 30th, 2006, 4:56 pm
by Custommx3
ECM = ECU, its under the radio
