Abs light on
bluebloodedforever
Abs light on
Post by bluebloodedforever »
hi guys just had new brake discs, pads and fluid done at the garage drove it out and the abs light comes on and stays on is there any obvious thing its never done it before please help
Aston Wards
Post by Aston Wards »
try resetting the ecu...., pull off -ve battery cable, depress brake/pump brake, hook cable back up, turn ign
if this doesn't clear it, go for a drive, slam on the brakes, after checking there's no-one behind you :shock:
my guess is they've probably damaged a sensor, or unhooked something (most of the crap attached to the wheel-well is ABS-related)
oh yeah, if you want to check the proper way :roll: there's a trouble-shooting section in the online manual
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
