satalitte radios
Car Stereo/Alarm Discussions
mx3stylez
satalitte radios
Post by mx3stylez »
i have been trying to figure out the best place to mount this thing, and can't decide. there is simply no place on our dash ('96) to put these, and i refuse to put it up on the window. any suggestions, with pics, would be helpful
klze swap, wisco 8.5 comp pistons, pauter rods, act stage 3 clutch, lightened flywheel, UR racing pulley, flex-o-lite oil cooler, 2.5" custom exhaust with high flow cat, B&M short throw shifter, S&R cross drilled rotors, , B&G lowering springs, maxxim 17" gun metal rims, modded nissan injectors, walbro 255 lph fuel pump, areomotive afpr, msd 6a , magasquirt v3, and turboed
lakersfan1
Post by lakersfan1 »
Are you using a portable one with a cigatette lighter power cord, or is it more a permanent mount?
I couldn't get reception with the antenna anywhere, so I had to stick it to the roof just above the driver windshield. I run the cord through the driver door (weather strip holds it down) nad run the cord on top of my sin visors to hold it up.
Dali
Post by Dali »
ive got the cnet controlled one for the clarion :) just depends on which unit you have.
mx3stylez
Post by mx3stylez »
its a serius starmate. i wanted to hardwire it in for a permanite install.
chew*
Post by chew* »
top of roof next to windshield dead center is best place for reception, an alternative location is at the rear top of the hatch.
lakersfan1
What I'd do for hardwiring one in would be ditch the factory antenna above the driver's door and run the wire where the factory antenna went. Use some silcone underneath to seal the water out of that hole. Once you start satelite radio, you'll never want to tune into regular radio again anyways. The only local channel I listen to anymore that's actually on the airwaves is ESPN Radio, which I get on XM Radio anyways.
Dali
Post by Dali »
the sat antenna end will not fit down the a pillar, only way i could see doing it this way would be to cut the end off and replace it after you run it. only thing is you will not be able to move it afterwards.
mx3stylez
Post by mx3stylez »
i actually got my antena shaved when i got the rest of the body work done, i may through the hatch, or would under the hood be a good spot too? as for the head unit, what have you guys done with that?
Return to “Car Stereo/Alarm”
