[FS] low 13 second high 12 second mx-3 parts. PART OUT
Tyler17rose
Well nitrous took out my motor last night. The car was running low 13's high 12's. Im done with it and am moving on to my RX-7. So heres the list of parts. All parts are in cnd funds and im located in Ottawa, Canada.
- Mx-3 CF hood, original cnd group buy $400
- Custom audi bixenon projector headlights (REAL HID'S), hella ballasts, hella FF50 driving lights, all in custom mx-3 housings. Custom headlight wiring harness: $400
- Custom Stainless mandrel bent 2.5inch exhaust from headers back. Gutted 2.5inch cat (pipe through it), Thermal Resonater, Racing Beat 2.5inch muffler, over axel, hangs on stock hangers. $400
- SS autochrome version 2 headers (flex pipe) Stainless steel, good shape. $200
- Momo steering wheel hub for mx-3 $45
- B&G springs, Tokico Struts, dust boots, top hats, camber bolts all new last year. $500
- Stock 15's 5 star mx-3 wheels, Hancook K102 tires 80% tread left. Rims are made by enkei, and are super light $300
- Stock Black Mx-3 hood $100
- Stock headlights, the set, pretty clear $30
- Pacesetter adjustable short shifter, SRD shifter bushings. $70
- CZT 67mm throttle body (KL36), beefed up throttle linkage spring, seealed throttle plate. $200
- Curved kneck ported KLZE intake manifold. Semi polished, knife edged inlets, Comes with all VRIS, red painted fuel rails, ZE injectors. 200
- Mike Seli reground intake cams. Grind: 0.353" lfit, 209deg @ 0.050" KLDE exhaust cams (better for nos/boost) $300
-Race Ported and polished KLZE heads. 3 angle valve job, resurfaced faces. only 6000km's $300
- 94 Mx-3 Disty, modified cap for external coil. Internal coil worked perfectly and is still in tact. Cap and rotor are almost new.
- Interprep valve springs /de retainers $150
- Megasquirt V2 with extras. Comes already wired into an mx-3 harness. Ready to plug in and go with a N/A KLZE tune, on my motor it was around 190-200whp, trapping 98-99mph $400
- MSD blaster 2 coil, Mallory Highfire 6AL Digital ignition box, coil bracket, MSD 8910 tach adaptor: $300
- MDX udp, silver. Fixed timing ring problem $40
-Toga HV oil pump, 6000km's $50
- KLZE phenos $50
-Mx-3 GS front bumper/lip, small crack on lip, black in colour $200
- NEW last year brake calipers all around, painted red, perfect condition only 6000km's. Slotted rotors new last year all 4, pads are still decent $350
- Goodridge Stainless braided brake lines all 4 $50
- Clutchmaster Stage 3 clutch, Mx-3 flywheel, lots of life in the clutch, was holding estimated 260whp perfectly fine. Chirps 3rd all the time $150
- Mx-3 GS tranny, no grinds $200
- SRD Billet aluminum crossmember (mx-3), scratched up from being dumped. Still stiff as hell, big upgrade over stock $100
- Rockford Fostage components (mids, tweaters, and crossovers) custom mounted in black mx-3 door skins (pw, pl) perfect condition. Song 222W amp and RCA's $150
- Brand new this year mx-3 Gas tank, maybe 1500km's on it. $100
Tons of parts im sure im forgetting. Complete mx-3 GS willing to part out. Lots of new parts. Heck i think the only thing not changed on this thing in the past 2-3 years is the control arm bushings. Endlinks, balljoints, trailing arms ect have all been changed recently.
Take the entire car as it sits for $5000 (minus the nitrous)
All parts are OBO, some i'd rather keep local. But willing to ship everything at the buyers expense.
- KLZE phenos $50
Last edited by Tyler17rose on September 17th, 2006, 2:23 pm, edited 1 time in total.
Mods:
Tyler17rose
some pics of the build last winter. And pics of the headlights/car:
Mods:
Tyler17rose
Mods:
Tyler17rose
Once i get my digi camera back from a friend i can take a pic of anything you guys request.
+++ note heads were resurfaced and valves were ground after above mid porting photos. +++++++
Mods:
- mitmaks
pm sent
Tyler17rose
Never actually got it to the track after the megasquirt install and tune, but im sure i was running low low 14's because i was taking stock SRT-4's on the highway and from a dig, stage 2 SRT-4 was kneck andkneck, took down G35's like nothing.timpronk wrote:Out of curiousity, do you know what it ran all motor?
Id say 14.3 ish.
Mods:
- Dali
email me at unclesluggo@shaw.ca i want the brake lines and toga pump. thanks.
hgallegos915
YOU sir will be my hero if you sell me the top transmission mount!!!! PLEASE
-hec
- mx3autozam
2RotorsNaDream
LooseChangeRacing
Throttle Body is mine
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
1993 Mazda RX-7 Touring Edition
