94 mx-3 b6ze smoking. HELP!!!!!!!!!!!!!!!
izzy2206
Post by izzy2206 »
My mx-3 is smoking alot at start up and when u get going it stops smoking so much and eventually stops. Any ideas what it could be?
Help!!!!!!!!!!!!!!!!!!!
Bumpysbro
Post by Bumpysbro »
my guess would be valve seals.
Tunes67
Post by Tunes67 »
If it smokes for more than a few minutes at start up.. its probably rings. Valve seals could need replacing as well.. but usually any oil drip down from valve seals will typically burn off in less than a minute. If the smoking is lasting longer than that.. its probably your oil control rings.
Tunes67
izzy2206
Engine rebuild kit. Help!!!
Post by izzy2206 »
Does anybody know where i can get a rebuid kit for a 94 mx-3 1.6L b6ze engine.
