To Supercharge a KL-ZE ...
Hello guys
I was wondering a while back, about the things i should do to the Ze when i swap .
I had ideias for :
Twin Turbo it
Big turbo it
Turbo and Nitro it ...
These days i had a new ideia, how about SC it ?
I have done some search ( really \0/\0/ ) and found out that the problem is on the low compression of the ZE.
Isnt Outlaw Enginering solving this with their product ?
Or is that part only for the intake manifold body ?
Doesnt it raise the compression ?
If it does not, how can a guys raise the Ze compression ?[/list]
I had ideias for :
Twin Turbo it
Big turbo it
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
- MechaManZero
pistons
							Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
http://www.procharger.com These guys make a universal SC for imports or compact cars. If you are going to SC the KL-ZE should be able to take 7psi stock but what I am going to do is jsut build the motor up first. Biger fuel injectors lower comp. pistons cams valve springs. I am going to do water injection to cool it down. Biggest thing is tuning of the car so you dont blow it up.
							1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
Hey many thanks Legato626 , i enjoyed the website
Since the Kl-Ze will be a swap, i dont want to go overboard and ruin a perfectly good engine ...
I will take care and tune it with the best, and the best way i know how
				Juans_93_MX3
Look into a Roots type S/C
From what i understand, only problem with a S/C is that there is very little room in the engine bay
And no-one, has yet to make a reliable transfere shaft
2008 Mazda 3
1993 MX3 GS
						1993 MX3 GS
I removed all my A/C stuff and i now have a big hole down there were the A/C pump was. I am going to make a mount and put a pro charger down there. I already have the piping planned out and the space. I just need the money! =)
- monty73741
Steeb wrote:if only i could bring myself to remove the a/c...
look on jeff abrams site mazdamaniac.com
he has a super charger build up
he didnt use a klze because of the compression he used a kl03. He also thought that the 200 hp from the ze wasnt true,
the kl03 is a cheaper engine i think its about 189 hp & has better compression for a turbo or supercharger
Jason Danaher
Please Help Support MX-3.com
- Aston Wards
				LooseChangeRacing
now wait....i think the only problem for fitting that mx6 supercharger would be the height until you hit the hood correct....everything else should line up or am i missing something
							http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
