96-98 Kia Sephia Transmission (GS, 1.8L DOHC MT)
90-94 Pro LX mounts or 96-98 Kia Mounts (does not matter that I found out)
Kia Sephia Speedo gear (part that goes into tranmission, not the cable)
96-98 Kia Sephia Axles and Jackshaft (again, gs 1.8L dohc MT)
And here are the offical Mazda Part #'s for the rest:
Differential & Ring Gear (MSP LSD)
GS01-27-190A
QTY = 1
Drive Gear
G501-17-341A
QTY=1
Bearing(s)
G5R0-27-350B
QTY=2
Although it is reccommended to get locknuts I say to just use your old ones. I got two new ones from Mazda and only one fit the kia transmission.
BTW this swap is done so you do not need custom axles. I got Kia axles and they are thicker than Pro LX axles and are stock units so they are only a part store away rather than 2 weeks out and $65 vs $250.
The Drive gear had to be grinded down around the inside ring to fit on the MSP LSD, and there was a part in the tranny that needed to be grinded too, but besides that (which are way easy to do) it was a very very easy LSD swap
More info when pics become available...
