I have a 94 DOHC MX-3 (B6) 1.6 Liter 4CYL.
It was diagnosed with a bad distributor by a reapir shop.
I reaplced the bad dist. with a remanufactured one and it started up just fine, but smoked and pinged. I thought I set the timing, but I can see two small marks on the harmonic balancer. I don't know what mark is the right one.
I finally convinced the part store that the coil was in the dist.
(AFTER YOUR REPLIES, THANKS AGAIN.)
The are ordering me another dist. Should be here tommorrow.
Once I get the dist on and ready to crank it up, how should I go about setting the timing. STEP BY STEP.
ANY HELP WOULD BE MUCH APPRECIATED.
I AM TRYING TO DO THIS MYSELF,
NOT AS EASY AS MY 70 MUSTANG.
