V6 Oil cooler issue
- mx3autozam
V6 Oil cooler issue
When I swapped my ZE in it leaked oil from teh oil cooler.The filter is tight and it dripped like crazy.. Got a gasket from Mazda and it didn't help it and it still leaked. Took that off and made one with some high temp gasket paper and used some RTV sealent on it.It did not leak I was happy. Its been about 4 days and i've stopped driving the car because of the leak is back. Has anyone else encountered this and what is the best solution
Thanks
John
Thanks
John
93 Mazda MX3 KLZE Turbo
Have you checked the oil pressure?
maybe u have excessive oil pressure casuing a leak, however in all likelyhood your oil light would be on ( if it is working properly).
Also, it is rare but the cooler can have a spilt in it is very hard to see.
I would take it off and check for any hairline fractures.
Cheers
Wino
Cheers
Wino
- jschrauwen
May sound dumb, but there are those that have forgotten the previous oil filter rubber ring behind when changing their filters and end up with 2 rubber rings between the filter and the oil cooler. Check to make sure you only have the one from the filter itself and that's it. If what Wino says is true, I believe that the old K8 oil filter would be the same and if you still have it (the old K8 ) trying swapping that oil filter mount on.
- 93-Spec-Edn
- mx3autozam
- jschrauwen
John, I wasn't referring to the gaskets that mount the oil cooler itself but the rubber rings that already come with every oil filter itself. Sometimes when the oil filter is replaced the old rubber rings gets stuck or inadvertantly left behind. Then the new filter is crewed on andthen you'll have 2 rubber rings between the oil filter and the mount. That may possibly account for the leakage, but a wild a-- guess at this point.
- 93-Spec-Edn
No theres another one below it. When u take out the filter theres a big a-- bolt and then the unit drops and theres an o-ring there.mx3autozam wrote:Its where the oil cooler mounts to the block!
like this 3 bolts hold it
John
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
