Seat Relocation Via Brackets
Cy
Post by Cy »
I took out my rear seat(s) and i'm 6 foot.. so my plan make rails to move the seat back 3 or 4 inches and down 1 or 2...
anyone have any suggestions?
GregoryChristian
Post by GregoryChristian »
Didn't I just read this post on another thread somwhere ? :laugh:
Cy
Post by Cy »
GregoryChristian wrote:Didn't I just read this post on another thread somwhere ? :laugh:
...that was not nessicary...
GregoryChristian
no harm meant ...but as far as moving your seat back I dont' think anyone here has done that , you may have to take you car to a local body shop :)
Cy
Post by Cy »
GregoryChristian wrote:no harm meant ...but as far as moving your seat back I dont' think anyone here has done that , you may have to take you car to a local body shop :)
you haven't seen my Craftsman Rx-7
http://www.themoosehorn.com/Personal/sp ... man%20Rx-7
That's mild bar... when i make the bracket i plan to use 3/8's walled square tube steel and i'm going to cut the front riser so it's flush to the floor...
Then i'll make an H Frame with wings on the back to mount to the stock rear seat bolt holes.
PATDIESEL
Post by PATDIESEL »
DAYYUMM, I needs me one of those for my Snapper!
Just FYI, Chris (greenturd on here) is 6'5" and fits just fine. I cannot see all this seat moving being necessary for only a 6'er :wink:
Cy
Post by Cy »
i'm 6'3" 260lbs... size 16 shoes... and Mx-3 is a small car for me...
I currently drive a 01 honda accord 4dr manual and although it is roomy... i feel tight in it..
I drive VERY agressively with my hands always on the wheel and shifter ...When I need to get it the wheel around while shifting, I don't want my legs in the way...
I have the seat all the way back in the mx and it's not a comfortable position for me.. so this will also allow me to shim the seat up to adjust the a-- part of the seat for tilt...
With all grade 8 bolts, lock-nutz and washers.. It AINT comin ooot..Also that's a 10 minute rough draft... but i'll be able to mount the seat anywhere from stock location to 3-6inches back...And it will be able to use the stock sliders with some modifing... so i'll be able to put the seat only a few inches Back and then slide the seat around :D
Return to “Appearance”
