Can this CAI be used on the V6 1.8 DOHC ?
netcom
Post by netcom »
2005 Acura 3.2 TL
1994 Suzuki Sidekick 1.6
1988 Mazda GTX (SOLD)
1984 Lotus Espirit 2.0 Turbo
1969 Firebird 400CI Ram Air III
1992blazeredgs
Post by 1992blazeredgs »
Yes that can be used on the K8. But on another note if you search on here you will find this question answered a million times over. There is even a "how to" at the beginning of the forum that discusses the different options you can use and what to look for when making your own cai.
Nate
Looking for another Red GS.
Spinkx79
Post by Spinkx79 »
Hopefully you noticed the shipping cost to Canada?
Chemical
Post by Chemical »
On the same note, you are right it has been answered but the guy has a point on this kit. I've never seen it and the item only describes it as mx3 not 4 cyl or V6. Looking at it you would assume it would fit but you know what you do when you assume.
Looks like a great kit actually and if it was in the UK I'd buy it but i'm not paying that for shipping!
1992blazeredgs
Actually the link says its for the sohc 4 cly only. But i still think it would work because an intake it nothing more than piping and couplers. Pretty simple. It has the two nipples needed to replace everything on the stock intake. As long as it is the right diameter i cant see any reason why it wouldnt work.
Nat
Hoodzy
Post by Hoodzy »
you could probably get an integra intake and save urself like 20 bucks
1995 Creek Mica Blue GS
BornSticky
Post by BornSticky »
FITS: MAZDA MX3 (93-97) 4CYL SOHC ENGINE MODEL ONLY
read the website before you ask a question.
Integra intake is the easiest way to make cai takes like 2 hrs for someone who doesnt know what they are doing u just need 2 couplers to put maf in the middle of it
hoodzy has great write up for it!
#5389 to join MX-3.com
Hoodzy
Post by Hoodzy »
now that i look it looks pretty damn close to my intake set up thing is the smaller piece, looks a bit too small and i'm thinking wont fit to go around the battery
i screwed mine up and its super tight around the batter, which causes my pipe to not be straight in line with the tb.. so i would say no it wont fit.. i had quite a bit chopped off my smaller piece that i can recall
