I have a '93 Mx3 v6, with electrical door locks.
Suddenly the door on the driver side, refuses to be locked by the key, I can unlock it, the key just won't go clockwise. I can still lock it from the inside. Can this be electrical (loose wire or something) or is it mechanical in the lock?
I'm also having a bit of noise from my heat-fan-motor (no AC). This noise is only evident after driving quite a while, probably an hour or more, I guess it could be a bearing, any suggestions? Do I have to replace the whole motor?
Regards
Svein
