Right- search engines not givin me any satisfaction.
I'm sure i'm not the only one with annoying noises from door trim. They seem a bit too flimsy and vibrate n squeak. Anyone come up with a solution? I thought about reinforcing them some how.Anyone done this and what did you use?
Also I have rattles from the rear hatch. I thought it was the boot lock at first. No. Then the jack. No. I cant find it and its driving me mad! It's not the plastic trims around the hatch either. Anyone give me a clue?
Door card and other rattles.
- neutral
Re: Door card and other rattles.
When that happened to me it turned out to be a slightly loose 3rd brake light mount. Tightens in 2 spots from inside the rear hatch. Worth a closer look maybe? Drove me nuts too til I found the prob.Chemical wrote:I have rattles from the rear hatch. I thought it was the boot lock at first. No. Then the jack. No. I cant find it and its driving me mad! It's not the plastic trims around the hatch either. Anyone give me a clue?
