So my BPT swap is finally almost done. I just installing the Greddy e-manage ultimate ecu but I need a pinout diagram to know which wire goes where.
Does anybody have a BPT ecu pinout diagram or know which pinout diagram I can use.
needed pinout diagram
get a Protege LX ECU or a look @ one... find the matching Mazda Pinout Diagram and wire away...
I'm going to guess it will be either Diagram m5 or m7 because the BP was in the Miata and so i would assume they used the same ECU harness...
IF you already got this done posting this information would be VERY nice as I also plan to get the EM-Ultimate...
