PCV Valve
Black4CylMX3
PCV Valve
Post by Black4CylMX3 »
Does anyone have a picture or something that shows where the PCV valve is located on a mx3?
ariesdude
Post by ariesdude »
94 Mx-3 Precidia
Black4CylMX3
Thanks, greatly appreciate it.
WingleBeast
Post by WingleBeast »
if you were to install a oil catch can, wouldent you want to hook it up to the other hose coming out of the valve cover (upper right hand side of the picture)
if im not mistaken they both do the same thing, just at different spots in the intake
that being said is there a way to hook it up to both with one oil can?
