O-Ring seal help.
Posted: January 14th, 2006, 10:17 pm
by Amber
HOW DO I GET THE O RING SEAL TO STAY IN PLACE ON THE WATER PUMP WHILE INSTALLING THE WATER PUMP???????????
[Admin: quit posting in all caps, this isnt an AOL chatroom]
Posted: January 14th, 2006, 10:24 pm
by JWMX3
your supposed to put rtv gasket sealant on both sides of the water pump gasket before installing it, when u do this, the sealant will make the gasket stick to the pump while u put it on the engine
Posted: January 15th, 2006, 9:15 am
by lakersfan1
Yep. Buy the sealant that specifically says 'Water Pump Sealant'.
Posted: January 15th, 2006, 10:15 am
by jschrauwen
Hmmmmm, never used sealant and was a bit of a trick to keep the o-ring to stay in place but I did. Never had a leak without RTV, I let the gasket make the seal.
Posted: January 16th, 2006, 2:56 am
by PATDIESEL
Yeah, I've never heard of RTV on both sides either. I use just a tiny bit to get the gasket to stick, but not enough to make any kind of seal other than the water pump gasket provides itself.
Posted: January 16th, 2006, 11:14 am
by JWMX3
yah the haynes dosent specifcally say both sides, but the instructions that came with my new pump did :shrug: cant hurt
