HOW DO I GET THE O RING SEAL TO STAY IN PLACE ON THE WATER PUMP WHILE INSTALLING THE WATER PUMP???????????
[Admin: quit posting in all caps, this isnt an AOL chatroom]
O-Ring seal help.
- jschrauwen
Hmmmmm, never used sealant and was a bit of a trick to keep the o-ring to stay in place but I did. Never had a leak without RTV, I let the gasket make the seal.
- PATDIESEL
Yeah, I've never heard of RTV on both sides either. I use just a tiny bit to get the gasket to stick, but not enough to make any kind of seal other than the water pump gasket provides itself.
