Fuel INJ Fuse Keeps Blowing!!!
the fuse that is located under the hood.. its a 30A Fuel Inj Fuse..and for some reason..it keeps blowing now..when the car ran perfect..2 seconds before it stalled...its a 1993 MX3 1.8v6.5spd....i just spent 300$ at the mazda dealership i was at..on plug wires..n bearing..but when i went to leave..it died..unfortunaly they were closing and my car was getting locked around back ,so i couldnt play with it other than jiggle some wires and try a few fuses..5$ each!! if nebody has ne suggestions..as wat to try...when i go back on monday..that would be helpfull..,im going to ask the mechanics that werk there for suggestions..aswell.
- FlyVFR
This thread may help a bit. I believe Grants has a few good pointers.
http://mx-3.com/phpbb2/viewtopic.php?t=48214
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- FlyVFR
I would follow the procedure in the online shop manual.93_mx3_gs wrote:Kinda off topic but how do I release the pressure for the fuel system so I can stick a new filter in ?
Just pop the gas cap ?
BTW - poping the gas cap only lets out gas fumes from the tank.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93_mx3_gs
FlyVFR wrote:I would follow the procedure in the online shop manual.93_mx3_gs wrote:Kinda off topic but how do I release the pressure for the fuel system so I can stick a new filter in ?
Didn't see anything about pressure release procedure in the manual. I checked F2 - 109 or something like that for fuel filter replacement.
On topic : Look around the fuse block housing for damaged wires and what not that may be arching and grounding out.
- PATDIESEL
To release the fuel pressure just pop the gas cap and pull the FI fuse. Some will still squirt out when you pull the line, but not much.
Ok..i figured out wat the problem was, after i went to mazda to play with the wiring , with a hand full of fuses..! 1 hour goes by,i counldnt figure it out..after i unhooked the injectors,chopped a few wires,,and pulled off alot of tape.. to trace some wires.... so i rented a dolly and towed it home, and looked around some more and kept unhooking stuff ,,until it would stop blowing fuses, Finally!! after i had almost everything unkooked,,i narrowed it down to the Rear O2 sensor.! i suppose the heating element had collasped and was causing a nice short!!!
- FlyVFR
That's some good troubleshooting. Saved yourself a few $$ also.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
