No spark from coil
Posted: December 18th, 2005, 12:57 pm
Hi all, newbie here to forum,
here goes
I have no spark from coil to disty or vice verce. No spark at any of the plugs either. Just died while driving normal condition. Hasn't started since. Cranks just fine. Definately getting fuel out of fuel filter. Disconnected and had partner pulse start to see fuel spurt with each attempt.
93 mx3, 1.6L 4-cyl SOHC with STOCK external coil. 4 pin electrical connector to disty, NOT 2 connectors (3pin and 6 pin). only one.
Replaced the following parts BRAND NEW:
Fuel pump
Fuel filter
Ignition coil
Cap
Rotor
Plugs
Wires
Still no spark anywhere. Grnd to ten reviels code 2 NE-signal Distributor.
Is there a HEI mod for my disty with a 4 pin connector that has a stock coil from factory. No mods ever done to this ride.
I want my spark back
A few of you made mention of replacing disty and STILL not getting spark. I don't want to shell out the $$$ for a disty replacement that might not work.
Anybody???
here goes
Fuel pump
Fuel filter
Ignition coil
Cap
Rotor
Plugs
Wires
Anybody???
