No spark from coil
moejoe21
No spark from coil
Post by moejoe21 »
Hi all, newbie here to forum,
here goes
I have no spark from coil to disty or vice verce. No spark at any of the plugs either. Just died while driving normal condition. Hasn't started since. Cranks just fine. Definately getting fuel out of fuel filter. Disconnected and had partner pulse start to see fuel spurt with each attempt.
93 mx3, 1.6L 4-cyl SOHC with STOCK external coil. 4 pin electrical connector to disty, NOT 2 connectors (3pin and 6 pin). only one.
Replaced the following parts BRAND NEW:
Fuel pump
Fuel filter
Ignition coil
Cap
Rotor
Plugs
Wires
Still no spark anywhere. Grnd to ten reviels code 2 NE-signal Distributor.
Is there a HEI mod for my disty with a 4 pin connector that has a stock coil from factory. No mods ever done to this ride.
I want my spark back :cry: A few of you made mention of replacing disty and STILL not getting spark. I don't want to shell out the $$$ for a disty replacement that might not work.
Anybody???
skylineracing07
disty
Post by skylineracing07 »
i have a spare disty laying around i will sell it to ya for like 30 + shipping i bought it for 75
moejoe21
Post by moejoe21 »
Can you give me an idea of what kind of shape its in? Is it OEM or aftermarket? Is it the 4 pin connector type? My system uses a stock external coil. If its from a 93 1.6L SOHC we might have a deal. Maybe you could email me some pics.
Thanks skyliner
