Tubro kit for MX3 -95 B6 1.6
Help! What turbo kit i can fit for B6 engeen. A lot ofers turbo kits for miata 1.6. Is that suitiable? May be somebody charged MX3? Thanks a lot all members and admins.
actually if i understand you right... your asking about a 1.6l from a 95? that would be dohc and you can use the turbo and manifold from a 323 with a b6t in it. it should bolt right up, you might have to dremel a little bit but thats nothing major.
Turbo kit 1.6
I recive reply from "Turbo specialties" that only manifold is different, now i am waiting for a picture of manifold that they use. Dimentions is very close,
for Protege 1.6, just drill 4 new holes for mount.
