wideband O2??
wideband O2??
where would i get a wide band o2 sensor for my DOHC B6?? What is the price range for those sensors??
- Yoda
You just can't plug a wide band O2 into your car and expect it to work. A wide band O2 worked on a 5v signal were a regular O2 has a 1V signal. To make a wideband work on your car you would need some sort of electronic circuit to be able to handle the signal of the wideband then convert the signal back to a narrow band 1V signal that your ECU with understand. Cost at least US$300-400+ to drive a A/F meter and convert a signal back to 1V. For one that will have direct benefit to your engine
I think this is what you want:
"AEM Wideband UEGO Controller Air/Fuel Ratio GaugesAccurate, high-tech gauges!
AEM's Wideband UEGO Controller is now available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! These air/fuel ratio gauges feature an LED readout and sweeping LED "needle" that changes colors as AFR changes from rich to lean. The unit's 52mm (2 1/16 in.) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. "
Can be found for $377.95 at :
http://store.summitracing.com/
Turbo 94 Protege LX
Innovative Motorsports has a wideband controller + sensor available for 200 dollars (both the controller and sensor together). It has two programmable outputs. You can program one of them to emulate a narrowband sensor. Very slick setup.
http://www.tuneyourengine.com
my cardomain site: http://www.cardomain.com/memberpage/793483
