well today i was just going down the road and the car just dies and then if i wait awile it will start and run fine but then it will just die randomly ? any ideas on what is my problem?
Thanks
car just dies
car just dies
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
i was also thinking the temp sensor but the car will run at operating temp or not and it doesnt over heat it just kinda dies without warning, could it be my fuel pump ?
CTC Racing
92 1.6L
92 1.6L
- Mazderati
If its your fuel pump, it will usually just die totally. Could this be ignition related? Electrical prob maybe?
96 GS, 17" Niche's, Falken 40's. Eibach springs, Tokico S/R struts, Ractive front & rear strutbars. Supertrapp exhaust, K & N intake. Soundstream Reference, JL & Eclipse audio.
Green means "Go", Yellow means, "Go Faster"!!
Mazda_Power
- mycarhatesme
do you know about the wiring? electrical is tricky as hell. If you dont know much, there is still stuff u can do....
check all connections...
check for burnt wires...it does happen.
check for loose connections (not snapped in) <- i know mechanics can be messy with this sometimes.
So, if you hit a big bump, enough to move stuff, or catch the wind at the right angle, or even hit the gas hard if your motor mounts are weak or old, connectors can come loose. Trust me. i just spent 100 bucks on a sensor and it was just a loose ground cable..it affected my idle coming to stops. it just does/did weird stuff. again electrical is not for the weak hearted lol.
dunno what else i can help with but if i can help more i will.
My names Dave, and Mazda has direct access to my bank account...sighs...
